Originally Posted by thomason2wheels
High air pressure will be much less likely to cause rapid wear than pressure set too low... same goes for the grip of the tire, too liitle air compromises traction more than too much.
The same here. With too low pressure Teresa behaves, well, strange when cornering. Too high is strange too (at least with these K73s), but too low is definitely much worse.
