Old 10-18-2012, 02:54 AM   #1 (permalink)
oil pan 4
Just picked up a roof rack. (Ideas for cheap and easy DIY quick disconnect system?)
I picked up an OEM looking roof rack from the junk yard today, held on by 3 sheet metal screws on all for corners.
I do need a roof rack occasionally.
The only thing is I don't plan on leaving it on the roof that the 95% of the time when I don't need it.
So maybe we can devise a cheap and easy quick disconnect system that any one can adapt and use on most vehicle and roof rack combos.
I was thinking about using hinges, taking out the hinge pin and replacing it with a clevis pin, cotter pin or high end QD pin.
Doing this would leave half the hinge on the roof of the vehicle and the other half on roof rack.
Does any one have any other ideas for roof rack QDs?
