Old 10-18-2012, 12:02 PM   #10 (permalink)
mattbatson
tow vehicle - '97 toyota 4runner limited
none - '09 honda civic si
none - '91 honda crx dx
sleepy - '91 Honda CRX dx
Ok, I'm a little confused
I thought to run waste veggie oil, that you had to refine it into biodiesel?
I had no idea you could simply take WVO and filter it and run it in your tank?
Is this the same as running new veggie oil in a separate tank (like the old greasel kits), where you dont turn on the veggie tank till the engine is warm, and then shut if off before you stop to avoid gelling in the engine?
Or do you run this WVO just like biodiesel?
1991 honda crx dx
1993 honda civic hatch
1997 toyota 4runner
2006 honda civic si
