Coyote X -
Originally Posted by Coyote X
ebay link here is the voltmeter I have connected to my wideband, it would work just fine to connect to pretty much any sensor on the car. It samples at around 1/2 second but for non diagnostic stuff it works great and is cheap enough to put several in monitoring different sensors if you wanted.
Also the sig is dynamic, I am reworking my site and it will be building a gaslog on there when I get time.
Kudos on the website. Great stuff. If you go to the ebay store for this seller and search "Auto", you will see lots of other digital meters for cars. By searching for "Auto", it seems like the input power voltage is setup for 12 volt cars (5-15 volts). Here's another voltage meter :
19.999V dc RED LED Auto Digital Panel Meter Voltmeter
http://cgi.ebay.com/19-999V-dc-RED-L...QQcmdZViewItem
CarloSW2
