Old 10-18-2012, 09:05 PM   #2 (permalink)
JRMichler
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 39.26 mpg (US)
What is the distance and elevation change on your commute? I see that the constant is exactly the same in both cases, 24.7. This implies that the elevation change is not affecting your mileage.
You could run another set of correlations by lumping all data together, with a to/from work variable. I use 1 for to work, and 0 for from work. The resulting coefficient is a direct measure of the effect of direction / elevation change / how tired you are / traffic variables / other confounders.
I regularly drive a route of about 60 miles with net elevation change of 800 feet. In the summer, I normally get 30 to 35 MPG uphill and 35 to 42 MPG downhill. The exact MPG depends on wind and temperature.
I also drive a 4 mile stretch of winding gravel road with 35 foot total elevation change. In the summer, I average about 38 MPG downhill and about 30 MPG uphill.
