Originally Posted by darcane
Good, another HX (sort of) and looks like your a local (I'm in Puyallup).
When you swapped, I assume you used the D16Y5 ECU, wiring harness, and O2 sensor, right? Are you using any sort of instrumentation to verify that it's going into Lean Burn mode?
Yes, I used all Y5 EQ! ECU, wiring and all. No instrument, any recommendation?
