Originally Posted by Outlaws69
D16Y7
SOHC, 16v, 85hp, 36mpg avg,
D16Y5
SOHC, 16v, 125hp, 44mpg avg
The biggest different is that the D16Y5 is a Vtec-E. it only operate 12v below 2800 rpm, it also has a lean burn feature that allows to to run 58:1 A:f ratio on 5th gear between 1900-3000 rpm depending on load. So in simple terms, if you stay off the gas paddle and below 70mph @2900rpm it uses 75% of the 1.6l and inject only 20% of normal fuel amount. Hope this help!!
Last I checked, the D16y7 is 106 hp, not 85, and the Y5 is 115 hp, not 125. You'll be gaining a bit, but not as much as what you posted.
Also, I highly doubt it goes as lean as 58:1.
More like 22:1, while the
Insight goes as lean as 25:1.
It'll be good, and I'd love to have an HX engine, but don't oversell your expectations.
