Old 10-20-2012, 11:19 AM   #5 (permalink)
kamesama980
the crazy guy in back
Cressy - '90 Toyota Cressida
Pickup - '91 Toyota Pickup base
Send a message via AIM to kamesama980
If the VSS in the transmission has 2 wires, it's a VR sensor, not a hall effect sensor. it produces a double sawtooth waveform with it's amplitute proportional to speed and proximity to the tone generating magnetics (in this case, the bolts) which is why the MPGuino doesn't see it at low speeds.
If you have a cable driven speedometer it's totally different and I'm in the process of figuring it out because that's how my truck is and my MPGuino doesn't like it.
Sme of the early ABS equipped cars as they get older, the wheel speed sensors start to lose sensetivity and cut out at low speed causing the ABS to kick on coming to a stop on dry pavement. Yours isn't a poor signal from age, it's just below the threshold of the MPGuino
-2003 Subaru Baja 2.5 5MT
-2005 Subaru Baja 2.5T 5MT
-1994 Pontiac Firebird 5.7 V8/6MT
-2001 BMW R1200c
-1970 VW Beetle
-2015 Prius (for the wife)
"You don't get to blame me for how I fix what you broke."
