I would suggest looking into adding a specific type of ash-less two stroke oil ("TC-W3") as a gasoline additive. The ratio varies from 1oz TC-W3 to 4 gallons of gasoline to 1oz TC-W3 to 5 gallons of gasoline; I use the 1 to 5 ratio (a 1 to 640 ratio). This will not increase BTU (it will probably reduce it very, very slightly), but it will increase lubricity and act as a top end lubricant. I use this in my own car, and yes -- I have seen increases in mileage.
