Old 10-20-2012, 06:29 PM   #7 (permalink)
AndrzejM
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Originally Posted by meelis11 View Post
I dont know what mpguino you have but it normally expects VSS input to be pulsed 12V.
If yours is 5V max, then you can probably change resistor(s) in VSS input (probably around 50K) to smaller value resistors (5K-10k maybe?)
My point is that instead amplify 5V to 12V you change resistors between VSS input pin and microprocessor (input to atmega can be 0-5V)
Changing resistor won't help if signal is below 5V, there is a Zener diode cutting the signal at this level, and resistor is cutting the current not voltage . So you need to amplify the signal.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
