Old 10-20-2012, 10:17 PM   #3 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Originally Posted by Electroddy View Post
If the brush holder angle is adjustable then reversing the angle is the right way to go. On the other hand, if the brush holder is riveted together, contact the mfg and try to get a reversed brush holder. Running a motor with angled brushes in reverse can cause the brushes to catch on the comm bars and destroy the motor.
Of course YMMV Bart.
I am a bit tentative about dis-assembling the motor. My track record in putting things back together and having them work again is not ... stellar ... that's why I'm not a mechanic
The manufacturer was bought out, or went under ... some time in the 1940's or 1950's (depending on your source) - so no joy on contacting them for parts.
I found a lot of issues with the wiring of the motor inside the 'conversion' I bought. So far, I'm trying to determine what the wiring SHOULD be so I can verify that it is running the wrong way for the transmission.
Thanks for the info - your solution is the least ... daunting .. so far.
