http://www.eurospares.com/graphics/c...CS for R6 hub/
I've added a some photos showing recent progress on the hub center FFE (funny front end) for my "gator-ish" project. I've made the bearing carriers and the new carrier for the 315mm Brake Tech/Axis cast iron rotor.
I didn't find a photo of how the lightening holes in the Axis R6 carrier were done until after I'd played things safe on the one I made. I'm not going to spend the time now to try and shave a few more ounces off since this will be a street application.
I was forced to do some tidying up in my office room and the garage as I couldn't find the small bag with the rotor buttons. It eventually turned up in a middle layer in a tub sitting next to the mill. I suspect it had been sitting on the welding table when I needed to clear it and all the miscellanous stuff got pushed off the table and into the tub. I must admit that the extra floor space in the office and the stack of empty boxes and tubs in the garage are proving to be mood improvers. :-)
cheers,
Michael
