Old 10-22-2012, 08:41 PM   #8 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by UltArc View Post
I believe pounds are weight, technically, but grams are mass. Correct me if I'm wrong.
But I am no assistance to this thread.
You are wrong. The NIST allows "pounds" to refer to pounds of force usually abbreviated lbf and pounds of mass (lb). In all scientific and engineering measurement systems, and by convention, the weight of an object is the force on the object due to gravity, measured in the same units as force. So 454 grams of mass on earth weighs 454 grams. 1 lb of mass on earth weighs 1 lb.
-m
The Following User Says Thank You to mort For This Useful Post:
UltArc (10-23-2012)
