Originally Posted by thingstodo
200 - 250F. That sounds reasonable.
Any idea what the 'half speed' input to the controller is called on a typical controller?
It's called "Half speed/reverse", you can also wire in a resister in to the throttle on a relay to cut the throttle in half if your speed controller doesn't have a half speed/reverse input.
