The wiki says my time was only about 1 hour. I didn't time it, and I did it in multiple stages, but it took quite a bit longer than that. Actual work time was probably 2-3 hours, but you'd need a couple more hours to let RTV set up.
Also, you put down that I saw a 4.1% improvement from the intake. While I did see a 4.1% improvement, I was also changing some other things at the same time. I'd only feel comfortable quoting 1-2% improvement from the intake itself.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
