Originally Posted by MetroMPG
turbocharging's efficiency gains mostly come from downsizing the engine so that peak power demands are provided by the turbo, while light/moderate loads are handled off-boost by the otherwise smaller engine. (Similar to the approach of hybridization.)
this is correct and where a large part of the gains come from.
another potential gain is that with an identical engine with a turbo, you can run along with a numerically lower FDR to drop cruise RPM and lower vacuum losses.
