Old 10-23-2012, 06:08 PM   #3 (permalink)
Sven7
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
If you can clear it, or even space out the rear end, get it as low as possible. Horizontal cutoff is probably best. There may be pre-existing holes in the fender lip for you to bolt a structure onto, which means you could go as low as the rocker panels. Check out basjoos's structured skirts for inspiration.
Just don't forget to make sure you can get the wheel/tire out- if not by simple clearance, perhaps by a hinged or removable skirt.
