Originally Posted by Otto
The plastic bumper cover is flexible: You can pull it outward an inch or so with your hand so that it is flush with the outer tire surface.
I'll try to do that and see what i can do with original bumper cover. Thanks.
Also, you can lower the car by cutting some of the front springs. On E34 BMW cars, cutting one turn off the bottom of the spring will lower the car by ~25-40mm.
I don't want to lower Berta, she's low enough for polish roads
If you pull the plastic bumper cover outwards and heat treat it to stay out or used a simple strut to hold it out, and also lowered the car by cutting the springs, you would not need the air dam.
I think I'll go into the air dam direction with belly pan, because I want to flatten the belly of Berta. You can see here
Three levels of Berta's belly that there are few things that can be improved.
You could also make an air curtain like the latest BMW 3 series cars have, by ducting ram air from the nose to a vent at the upper forward section of the wheel arch.
I'll try to find some details. But I have ducts from the front to the wheel arches, but those are for cooling the breaks.
