Old 10-24-2012, 09:41 AM   #1 (permalink)
Smokingwheels
Smokingwheels - '84 Nissan Bluebird wagon LX
90 day: 35.99 mpg (US)
Red Z - '79 Nissan 280 ZX
Blue Ford - '95 Ford Falcon GLI
90 day: 18.18 mpg (US)
Send a message via MSN to Smokingwheels Send a message via Yahoo to Smokingwheels
Has anyone tried this type of porting?
Way back in 2002 I ported an engine with a wire wheels. Long story but I ended up destroying the crank before I could control the strange timing curve.
See blue line on graph but this was with the compression up at 12.5:1.
In 2005 I tried again on another engine which is still running today but has been sabotaged once with silicon in the oil.
My timing on my engine runs similar to this pic
My engine is really touchy with the spark timing so its not set and forget..
If it goes out of tune it uses more fuel than it should like now I have lost one of my load switches to adjust the timing.
It used to have more power that normal until I overheated it in 2005.
I have been keeping some records over the years and have updated my fuel log with the good ones, sometimes it runs worst that a model T Ford...
1984 Nissan Bluebird wagon LX Gas Mileage (Smokingwheels) - EcoModder.com
I have had to put a second fuel pump in to keep up with WOT when it was in peak condition.
Warning if you want a temperamental engine that performs micricals sometimes then try this to you head ports and inlet manifold if you have a spare one and can program an different timing curve into you ECU.
