Old 10-24-2012, 01:36 PM   #10 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
With the lack of detail regarding whats its capable of, RPM rates, Tq isn't even included with the peak 40HP claim. I don't see this as much more than a generator like it steers toward with its description.
Someone mentioned in the gizmag comments about "not being RPM variable friendly" and another saying might "operate within a narrow power/rpm range".
Even if it operates decently within a givin power/rpm range, one could retain the use of the existing transmissions and low gearing for the low RPM variable diesel engine it could replace.
Unlike ICE having a small boost in FE when properly tuned with a turbo, it would be interesting to see the outcome of a turbo model of this "New Cycle" with regards to fuel consumption, heat, peak power/Tq?! ...If it ever comes to light. Maybe I'm over shooting what this engine is capable of though.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
