Originally Posted by dcb
I don't know the precision you want, but the only thing I've found in that range are micro flow meters. They use a funky "nutator" to measure down to
0.005l - 0.25l/min. They may be hard to come by, though.
_________________
I don't know the accuracy or whether they'd work with gasoline, but these are the smallest "cheap" flow meters I've found. They are all the vane type and are intended for computer water cooling.
The only information regarding resolution is "0.1l/min @ 1000rpm." Might be worth a look...they are cheap enough.
Innovatek Flowmeter Rev. 2.0
- LostCause
