Old 10-25-2012, 02:29 PM   #7 (permalink)
raylit20
Hakuna Matata
Avalon - '99 Toyota Avalon XLS
Originally Posted by c4a8l View Post
They look very good and a clean fitting.
Would the center cap be strong enough to hold it though i would be worried that it may come off when cornering?
The epoxy forms an incredibly strong bond between the cap and cap mounting bore when used correctly.
As to the cover to stud mounting, the lock nut positively secures the wheel cover to the stud. Neither are going to come off without prying on them with force. Remember to replace the lock nut after it has been removed and reinstalled a few times as the nylon locking mechanism distorts and wears with frequent removal.
If you follow the guide, the covers will not come off while driving.
I also have a DIY guide up for doing a clean mirror delete. - http://ecomodder.com/forum/showthrea...ete-23608.html
Simplify, then add lightness.
The Following User Says Thank You to raylit20 For This Useful Post:
WesternStarSCR (10-25-2012)
