Old 10-25-2012, 01:42 PM   #27 (permalink)
YeahPete
TheCav - '04 Chevy Cavalier LS
@ car_guy:
WOW you set the tire pressure over 5% max when cold? I usually fill it to max cold because when it heats up it will be well over max temp. The greater the cold temp the more pressure when it heats up.
Whats the pressure after the tires are heated?
Anyone else doing this? I was kinda freaked out going over max sidewall pressure because my brother destroyed a tire doing this but he put like 45 psi in a 34psi tire.
