Controller still wont work..
Sorry for not replying for so long. So i posted a few weeks ago that my controller wont work. So Paul wanted to know if the controller has 12v at j1. And yes it das 12v.
So My dad thought that i may had damaged a piece while i soldered it together so he started building up a new one. But here we have the same Problem. The yellow Led blinks. So we thought it is maybe the HAS 300-S so we bought a replacement. But with that new one still no change. So my dad played around with it and he removed the HAS 300-s. And did put 2 Resistors on the cable. In this case when you start the controller the yellow led is on all the time. But when you turn up the throttle it starts blinking again and if you go down with it it's on all the time again. And when you start the controller with a turned up potentiometer the controller blinks all the time. So we really dont know what to do anymore. I hope someone has an idea! Thanks!
