Old 10-25-2012, 09:22 PM   #3 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
what kind of specs do you need?
The easy option that I see is taking a cheap ($300) off the shelf 20amp inverter that has a 48v input, using a step up transformer to get you to the 144v needed or even tweaking it's voltage regulator to give you that 144v output then rectifying it.
otherwise I think some of the open source battery chargers that are large switching power supplies take a DC input and can give a wide range of outputs.
The Following User Says Thank You to Ryland For This Useful Post:
Cobb (10-25-2012)
