Originally Posted by BamZipPow
While magnets seem like a good idea, mechanical fasteners are a better bet to keep things in place. How many external panels do you find vehicles (airplanes, trucks, cars, buses, trains, boats, or helicopters) that are magnetic?
Almost all cars have magnetic panels on the outside unless they are made of a non-ferrous material
. I know what you mean though.
For the attachment though I am not willing to drill into the body. I have thought about having a little U groove attached near the top back and then creating a clamp to hold it on.
If I go the clamp rout it would probably be built like this:
1. Bolt
2. Metal washer
3. rubber washer
4. Cut washer (for use as a spacer that will be even with body)
5. rubber washer
6. Wheel skirt
7. Metal washer
8. nut
The nut and bolt might be replaced with something like a hood pin.
I could also mount it from the inside so the air pressure will push it tighter to the car.
