Originally Posted by MetroMPG
Properly done, P&G and clutch starting is no harder on the clutch than normal shifting.
Check basjoos' Aerocivic thread - he's got several hundred thousand miles on his original clutch, if I'm not mistaken, and he uses P&G a lot (or did in the past, before his lean-burn engine swap).
Had 515,000 miles on the car when I had the clutch replaced while replacing the engine and transmission. The clutch operated trouble free throughout this period and still had a fair amount of lining left on it when removed. Most of my P&G was done when going up and down hills and when approaching intersections where I had to stop and then accelerate. I rarely P&G on flat roads.
