Old 10-27-2012, 09:47 AM   #22 (permalink)
SecondWind
Bluemobile - '11 Honda CR-Z EX
As I am the OP on this thread, I'll say that the ScanGauge was re-calibrated between testing the OEM tires and the "tall tires". As I recall, the OEM tires used -3% setting, and the "talls" +7%. In both cases, the ScanGauge error was less than 0.1 mile in 10 miles. AFAIK, an improperly adjusted ScanGauge will affect both MPH and MPG readings.
