Old 10-27-2012, 10:07 AM   #14 (permalink)
ECONORAM
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by meelis11 View Post
I dont know what mpguino you have but it normally expects VSS input to be pulsed 12V.
If yours is 5V max, then you can probably change resistor(s) in VSS input (probably around 50K) to smaller value resistors (5K-10k maybe?)
My point is that instead amplify 5V to 12V you change resistors between VSS input pin and microprocessor (input to atmega can be 0-5V)
I tried that myself, and it didn't work...so I made a corroplast disk with holes, clamped it to my driveshaft, and wired in a 12v gauge bulb and IR sensor to read the light pulses. I'm on my third disk already, so the step up voltage sounds like a much better idea...
