Old 10-27-2012, 11:03 AM   #7 (permalink)
scivicblu83
scivicblu83's Avatar
experimental - '90 honda crx hf
90 day: 67.81 mpg (US)
yes, either with your mouth or vacuum pump pull a vacuum on the egr valve actuator diaphram, so it with the engine idling, if the passages are good the engine will sputter really bad from the exhaust gas being injested meaning you have open egr passages.
