It would seem the balls took longer to dry, however, there was less clothes/water (8.4 lbs vs. 16 lbs) in that load.
SUGGESTION -- weigh the clothes both dry and wet, so that you can know how much water is intrained in the clothes. That way you know the amount of water the dryer has to evaporate away.
