Old 10-28-2012, 12:17 PM   #9 (permalink)
Cobb
Are you talking about stopping mg2 to prevent "background charging? Many insight overs find that reduced fuel economy and happens with a bad ima as well as a starter battery. The drag alone is enough to prevent lean burn.
My thinking is since its a ECVT, you would get your best mpg at the top speed before it starts to "shift", or charge ratios.
