Old 10-28-2012, 05:44 PM   #20 (permalink)
1carnut
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
I also would like to know the difference(s) between the VX ECU and the HX ECU. I realize that one is OBDI and the other OBDII but I didn't have to use MMO and had lean burn whenever the engine was warm and I was using a light throttle on the VX. My guess is that this is probably the biggest reason that the VX got such higher mileage than the HX.
