Old 10-29-2012, 01:05 AM   #5897 (permalink)
jamesweirick5
Originally Posted by MPaulHolmes View Post
The troubleshooting guide is a good idea, but right now it's just people email me, and then I try to help them get it working. What's happening right now with it? Without the equipment, it can be tough to track down bugs. You could mail it here and I could try to see what's going on.
I have a BS in Electronic Technology with equipment and get the theary and concepts. I do not have your valuable experience. Your huge threads are difficult to process easily. I have converted 8 cars cheaply and my 20A chargers cost about $10 by using just a full wave bridge.
Your 500A to 800A controller is to complex to troubleshoot readily. If I had measurements (V) of the micro processor inputs and outputs under success and different failures, then I could troubleshoot the simple circuits left.
I have built a 1000A controller using your power driver and fets with diodes. I have bought a cheap PWM control to drive it. I will use smaller wire resistance to current limit at first. I still have to find a simple current limit cricuit to connect to the driver chip. I have upgraded your fets and diodes and mounted them on big heat fins with a fan for supperior cooling. This contoller costs under $200 in parts. I do understand the dire need for your additional complexities and computer. I know I will be blowing some stuff up but hope that you can reduce the failures.
Jim
The Following User Says Thank You to jamesweirick5 For This Useful Post:
MPaulHolmes (10-29-2012)
