Originally Posted by brucepick
However the HX has an electronically controlled EGR valve, has no vacuum hose going to it. Not sure when the Civic line got away from a vacuum controlled EGR. HX model began in 1996.
Then, reassemble car and run off cliff. buy obd 1 civic.problem solved
