Welcome. Sounds like your already on the right track.
Is your mustang a 5 speed or auto trans? Just looked Auto.
What gearing is in your axle?
I would only replace the water pump if you need a new 1 anyway otherwise it probably wouldn't be worth the cost.
Have you slowed down to the highway speed limit? I normally follow behind semis not tailgate because their speed limit is normally lower and their traveling slower anyways.
"The only real mistake is the one from which we learn nothing."
- Henry Ford
