Old 10-29-2012, 04:08 PM   #10 (permalink)
roosterk0031
I doubt any gains from electric water pump, for drag cars yes, but not for street cars. Drag cars it runs off the battery, street cars would run of alternator, so converting mechanical energy to electrical, then from electrical back to mechanical is inefficient.
Electric fans would be good since you've deleted the AC your fan is way oversized and at hwy speeds is not needed.
If you can fit some taller rear tires that will drop your HWY rpm's some, I'm sure you have plenty of torque to get them going, will throw the speedo off, but since it doesn't work anyway.
Air dam if you don't already have on.
