Old 10-29-2012, 11:51 PM   #3 (permalink)
1carnut
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
I don't have the answer for you but I can tell you that I experienced something similar a couple times in my 94 VX. It seemed to only happen if I tried to EOC two times without the engine running much in between. It seemed like it would take about 30 seconds of trying to start (acted like it wasn't getting fuel) and then it would start and run fine. I thought maybe fuel pump might be going bad but it ran fine aside from that. I just made sure that if I did any EOC, that I made sure that the engine ran a bit before I did it again.
