Thread: Wikispeed
Old 10-30-2012, 03:12 PM   #12 (permalink)
aerohead
Wiki talking points
I did some back of the napkin cyphering and came up with some numbers to consider.
*MOTOR TREND reported in January 1993 that they had run a Honda VX from Los Angeles,Calif. to San Francisco and back, and claimed 64.6 mpg.
*From Hiroyuki Ozawa et al. Japanese Society of Automotive Engineers Paper JSAE 9835285 for the 1996 Honda Dream Solar race car,their Road Horsepower graph would put a VX-like car at 10.7kW (14.348 hp) road load @ 55 mph.
*At 92% mechanical efficiency for the driveline,the shaft power would be 15.596 bhp.
*At 64.6 mpg and 55 mph,the VX would use 0.8513 gallons of gas/hour.
*0.8513 gallons is approximately 5.108 pounds/hour.
*At 5.108 lbs/ 15.596 bhp = 0.3275 BSFC.
*This establishes a BSFC for a very efficient HONDA engine.
*If the WIKISPEED car gets 114 mpg @ 67 mph,then it uses 0.5877 gallons/hour
*Or, 3.5263 lb/hour..
*At 0.3275 BSFC the Road Load Brake Horsepower would be 10.767 bhp.
*Again,at 92% mechanical efficiency,the Road Horsepower at 67 mph is 9.905 horsepower.
*From Ozawa's curve,and a 'test weight' of 1,400-lbs,the power absorbed by Rolling Resistance at 67 mph would be 4.11 hprsepower.
*Subtracting the R-R from the total Road Load yields 5.795 aero horsepower load at 67 mph.
*Using the aerodynamic horsepower formula,using standard air density,at 67 mph,the WIKISPEED drag factor would have to be 0.262 m-sq (2.822 sq-ft) to balance the energy equation.
*If we use the frontal area of the smallest convertible ever sold,the 1966 Lotus Elan,at approx. 1.304 m-sq (14.038 sq-ft) and solve for the drag coefficient,we get Cd 0.201 to balance the equation.
*The Mazda MX-5 Miata,at Cd 0.38 is at the lower end of the drag spectrum for convertibles.
*I have no idea how the WIKI team could achieve something around Cd 0.201.
If their car is any larger than the Lotus,the Cd will need to be smaller to maintain the CdA.
It would be polite for the WIKI team to provide more definitive data for their car.
2000neon (10-30-2012), mort (10-30-2012)
