Did you consider pulling off the big plastic interior quarter panel covers before heading to the Krown guy. If you remove the inner panels it is better than just removing the tail lights and shooting the product from there.
Also since the Krown guy won't do the floor from the inside , you should pull the seats and carpet to do the floor yourself. Cars driven in snow areas always have a wet floor under the carpet and insulation . The carpet may feel dry to the touch but the insulation will be wet year round.
Vx rocker panels are totally accessible from either end. A rubber plug at the front of the rear wheelwell and a rubber plug at the door post behind the front plastic inner fender.
Remove the front turn signal lights ( only 1 screw each ) to get the fender inner structure .
Also pay attention to the area below the battery
Just trying to help .. Good luck
