01 Honda Insight Beat Up Beauty, leaks and main harness bad
sWell I finally got my wish, I found a beat up beauty nearby, straight on the bottom but bent up top for a price I can accept.
Sadly I will need to use deepcycles to keep it running since the DC DC works and so does boost but the power doesn't make it to the battery. (battery drains with or without the BDC trick)
Very odd issue, I will need to find all the technical resources I can showing the various wires and grounding locations (and photos of them) so I can figure out what wires on the harness (which may be damaged) are not making connection.
The dash is water damaged (looks like LCD break when you push too hard in certain spots)
And a more pressing issue is the drivers door is a bit popped out and leaks along the top edge, not sure how to do it without breaking the glass.
Any insight enthusiest in Oshkosh FDL or Wausau willing to take a quick looksie so I can diagnose and fix her up more quickly?
I think I will need to run wires from the front to the back DC DC both hot and ground as I get no 12v power regardless of BCD setttings (and the DCDC was recently replaced, hence why I have the car)
I also have these issues
The four buttons in the instrument pod ( -, +, Trip, & km-mph) get corroded and/or dirty. While pushing in on the button, move your finger in a north-south and then east west manner. Do this 30-40 times and it will clean the micro film on the switch contacts. Throw in an occasional circular motion. Works.
If you have low mpg's, check the alignment especially 'toe' setting. Should be set as close to zero as possible.
Forgot about the wet seatbelt/damp floor issue, caused by leaks in the A to B
pillar trim over both doors . Will cause mold & musty smell. PITA to fix.
Pics showing the drivers side unibody damage, not decided what to do on that one.
Cheers
Ryan
