The temperature is getting pretty cold, but tonight I should have my heat all working. Last weekend I filled the system with antifreeze and changed over to using the stock radiator overflow container. All I have left for the heater is the circuit that turns on the relays when my Temp Control knob on the dash is to the full HOT position. I designed up the circuit last night and today I will pickup the parts and solder it all together.
I now have over 850 miles on the EV and still going! I got some new bolts for my suspension that I will install this weekend and hopefully by Monday I will be winter ready.
