Originally Posted by Daox
You really draw more than 210 amps continuous? That seems like quite a bit. I mean during acceleration it should be that high (and higher probably), but during cruising that seems quite. That is pushing out around 20hp...
No, I was going on and off the throttle with rolling hills when the ammeter was in the picture. 60 km/h (37 mph) is 90-100 amps on flat ground = 192-212 KWH (including field consumption) which is fairly decent, no?
