Old 11-01-2012, 05:11 PM   #9 (permalink)
mcguire
Twuck - '06 Ford F-150
90 day: 17.82 mpg (US)
Rudolph - '95 BMW R1100 GS
90 day: 35.37 mpg (US)
Terrifying - '02 Chevrolet Corvette Coupe
90 day: 28.4 mpg (US)
Big Red - '13 Ford F-150 XLT
90 day: 18.96 mpg (US)
As far as removing carbon, you can use a plastic water misting bottle. Bring engine up to full operating temp. Remove intake piping from intake manifold. Set to high idle and squirt (mist) water into engine intake opening. A pint or so should do the trick.
I tried this last weekend with my F-150, with poor results. If I removed the pipe from the throttle body, the engine died, presumably because the intake air sensor was no longer seeing the airflow. (?) If I disconnected the intake from the filter box, the engine died when I sprayed the water in, presumably because it was getting on the airflow sensor.
