Old 11-01-2012, 11:10 PM   #54 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by some_other_dave View Post
The 88-91 CRXes did have power-assisted brakes. You want them to be power-assisted; I used the brakes on my CRX after depleting the vacuum. It takes an unreasonable amount of pressure on the pedal to slow the car down.
None of the US-spec CRXes had power-assisted steering. There may have been overseas (e.g., JDM yo!) models that did, but none that were intended for the US. The car is generally light enough not to need it, especially if it's moving at all.
-soD
You were also fighting a 4.5lb/in spring and a giant diaphragm trying to push the entire volume of air through a 1/2" hose while simultaneously pushing the fluid into the calipers and wheel cylinders.
I build and adjust manual braking systems pretty often. The CR-X doesn't need assisted brakes.
