Old 11-02-2012, 03:54 AM   #2 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Closing the throttle pulls highest vacuum on the idle circuit, causing more fuel to n be pulled through it st higher RPM.
ENGINE OFF neutral coasting is the best option.
Clutch disengaged, trans in gear is quicker start up, but added drag. Trans in neutral is best.
