Old 11-02-2012, 08:22 AM   #9 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by broski499 View Post
I have an ultragauge hooked up and it has been calibrated
Can it display LOAD of the engine ?
See if there's much difference between the load at 55 and 60.
I have found that at just above 60MPH I get right round 40 to 42 mpg this is steady. On my way from Bakersfield to OC I got an average of 36 MPG on this trip. From what others have told me I should get better MPG at 55 but I don't isn't this strange?
Try the different speeds repeatedly - for a full tank - so outside influences start to even out a bit.
If the car stays in the same gear, the lower speed should get better FE.
If it drops a gear, you can expect FE to suffer.
