When I said egr, I ment the passages. Just unbolt the cover and clean them out and you can take your ever off, I just spray a shot of carb cleaner Ito the holes on it. Everything with a hole I spray into. Being careful not to put way to much liquid into the combustion chamber. Although carb cleaner evaporates super quick so it should be fine. Just follow the write ups you would find on google.
Also to better describe lean burn (im still new to this, but dont Worry you will Get it too some day) It's like driving down the road and you feel your car bogg down like the fuel injectors just got clogged or something but the only way to tell is with an mpguino if you are in LB or if your injectors are indeed clogged lol.
