My heat is working! I am using the stock climate controls in the Civic, which are electronic. So now I have it setup that the heater and water pump activate when the temperature control knob is all the way to HOT position. It worked quite well, gets hot within two minutes and is more than enough to keep the windows clear and the passengers warm!
I am guessing its 2 kW of heat, I will know once I get the gauges properly installed.
