Old 11-02-2012, 08:08 PM   #9 (permalink)
IamIan
IamIan's Avatar
I was kind of thinking this would be a fun DIY project.
I just happen to have a 350W PM scooter motor. I also happen to have 12V worth of A123 20Ah cells. While it may not be the perfect setup, all I would need is a controller and charger to get things going...
As long as you enjoy the DIY road trips , highs and lows together ... It will be fun ... it was for me.
From what you happen to already have you are off to a good start.
As long as you are only intending on using it to assist and make your pedaling easier ... ~350W should be fine ... do you know what voltage the scooter motor was originally used at?
